In that lovely Jag too.What's a 2hr round trip to somewhere as beautiful as Oban for someone retired?![]()
Update on Scewfix: I phoned them and they were very helpful: I just need to order and pay for the items and they will all be delivered to Oban, when I go up to collect they will refund me and I can use the gift card - getting a fast charger, 2 x Milwaukee 6Ah batteries, Milwaukee deep impact socket set and Milwaukee Impact adaptors.
M12 Stubby fuel ordered from toolstation.
So sorted and I hope @BrokenBiker s friend was just unlucky with Milwaukee, for power and size it does seem the best compromise.
Thanks again for all the advice
Thanks have just ordered the 5A High outputGo for the 5ah high output not the 6ah batteries. They’re only £3 extra each but a big difference.
Still a farce with the gift voucher
As you said “used by idiots” says it all ,in defence of a battery impact!Personally I would get every battery impact wrench and bin them. Nearly every M6 or M8 bolt I try to undo at work has been stripped by one of them used by idiots. I get so annoyed about this. And I get called a fossil for still using a ratchet.
Quite. I only want mine to undo. I spin on by hand and tighten with a torque wrench.As you said “used by idiots” says it all ,in defence of a battery impact!
On the 18 volt M18 Milwaukee cordless tools the "High Output" batteries can provide a higher output current draw ( known as "C" ) because, rather than 18650, they use 21700 Li-Ion cells ( 21mm diameter, 7 cm long ). Due to the increased diameter, 21mm vs. 18mm, these cells would not fit inside the handle of the 12 volt M12 tools, so I suppose they just are using improved 18650 cells with a higher "C" rating.Don’t ask me how the battery gubbins works but you definitely get more out the high output than standard.
NiceToolstation delivery and a drive to Screwfix Oban in the XJ6
Recommends for a batt ratchet 3/8 drive
Long n thin is ok the Millwauke above is to fat…
Don’t mind which make but stronger the better…
You need one of these as part of Milwakuee addicts therapyToolstation delivery and a drive to Screwfix Oban in the XJ6
Red and white. Very Christmassy.Toolstation delivery and a drive to Screwfix Oban in the XJ6
Careful, they might think it's one of their vegan sausage rolls!!!do you think if i spray my yellow hoard of Dewalt gear Milwaukee red anyone will know? and will my man bulge be bigger walking into Greggs![]()
Milwaukee M12C4 M12 4 Bay Multi Charger
Charges up to 4 batteries sequentially. By-pass mode to select the battery that gets charged first. Hang holes for vertical mounting. Compact in size.www.bigredpowertools.co.uk
