There's a seal missing in pic2.A few months ago now (!) we took a tile off the side of the bath to sort a leak, last night with some some careful use of a borescope and some string we managed to re-attach a pipe to the overflow.
Quite proud of that, been disconnected for years, apparently a plumber had previously said it couldn't be done without taking the bath out, and he'd blanked off the where it tees into the waste. Tested, all dry under the bath, jobs a goodun.
An hour later, the ceiling downstairs is all soaked.I think the bath waste must be completely disconnected from the soil stack for so much water to have escaped.
Cue an hour stuffing the borescope down beside the bog, under the basin, etc. Lots of water but no idea where the leak is. I think it's going to be a case of cutting some strategic inspection holes in the ceiling below next weekend.
Good eye, I didn't spot that until the fitting was back into position ready to tighten. Luckily I was able to stuff it through the hole in the bath rather than wrestle the fitting all the way back out.There's a seal missing in pic2.
Me too.I wonder what 'T' Urban District Council it was ?
Yes! introduced 1901 and still on the goCan you still get 120 roll fillum for that kind of thing ?
Yes, but 620 is harder to get. Not impossible.Can you still get 120 roll fillum for that kind of thing ?
I think the way round that if you have a 620 camera is rewind 120 film on 620 spools as the spools are the difference, the film itself is the same dimensionsYes, but 620 is harder to get. Not impossible.
Kodak made a lot of their cameras in 620 to drive refills their way.
Oh yes, you can do that, but how many people are going to want to do that? Not many, which is why you can still buy 620 from a few sources that have done just that for a small markup on the film.I think the way round that if you have a 620 camera is rewind 120 film on 620 spools as the spools are the difference, the film itself is the same dimensions
Hopefully this will slow the low-lifes down if
It was suggested to me not to make security too obvious on my lock up by a local crime prevention officer
Buy one for everyone in the street but give some of them cheaper padlocksIt was suggested to me not to make security too obvious on my lock up by a local crime prevention officer
I did consider that. I suppose we'll find outIt was suggested to me not to make security too obvious on my lock up by a local crime prevention officer
I did similar to my garage door back in the 80’s and also reinforced both sides of it to prevent them from being gemied open with a pry bar.
