MattF
- South Yorkshire
Have they improved the drip tray or is it still flimsy?It's out of the box.
I've still not yet received any resin or Isopropyl though. I'm thinking this'll be a next weekend play session now.
I'm going to stiffen that bench it's on, a bit, as that was part of a larger setup. It's lost a tad of rigidity now I've removed the rest of it.
I have left it for about a month without issues. Always stir it and check the film doesn't have anything solid on it.Another question. Can you leave resin in the vat, after use, else is it best to pour the remainder back into the bottle?
I've had some in the Jupiter for best part of 9 months - just printed with it yesterday (due to problems with the SaturnAnother question. Can you leave resin in the vat, after use, else is it best to pour the remainder back into the bottle?
I usually lower the bed a little into the resin to reduce surface area exposed to atmosphere
You going to sleep in the same room as the printer?This is the vat cover for the Mars.
Also wired up a permanent four socket extension for that bench, today, as there's no power socket in that corner. 1.5mm rubber flex. That stuff's like battling a snake when you're trying to wire up.
Yes, that is indeed my bed this rack is smack next to.![]()
What about the fumes?
I can think of worse ways to go.If I deem fumes are an issue, I'll sort something. I'm not overly concerned currently though.
