BrokenBiker
- Newport, South Wales
buying a new mig in next few days.
its no secret i am a fan of hitbox, cheap, cheerful and my TIG is faultless, so its no surprise im going for a hitbox mig. specifically the 250 amp single pulse inverter. i dont use it to put food on the table so i really cant see the point in spending thousands when in reality if the mig failed, i would just turn on the TIG and carry on so for just over 200 quid i think the hitbox will do for me.
every mig ive had til now, transformer or inverter has always been the usual voltage and wire feed settings, but this one has voltage and amps, plus a selection for whether you are using co2, ar/co2, or doing MMA, lift tig or gasless, and the videos i have seen show the amps knob also altering the voltage, so does this make it a sem synergic machine?
there is no input to tell it what thickness wire you are using, what thickness or type fo steel you are welding or anyhting like that but it seems to set the voltage based off the amps you want, then you can tweak the voltage either way with the other knob.
my current mig is a typical transofrmer with 1/2 min/max for the voltage so not entirely used to the machine picking settings for me, however i am going to need a decent mig again soon (foreshadowing) so ive just gone and got a bottle of 5% mix gas and ordered a 5kg reel of A18, gasless can stay on my transformer for now.
it comes with an mb24 euro torch which i think may be a bit clumsy for the stuff i do, so i will probably by a longer mb15 as well
