I did mention those 2 contacts in post 11I have worked out the 2 small black wires are the trigger, through those 2 little contacts behind the cowl, presume so machine won't start if nozzle isn't complete, there is also a thicker black attached to the air pipe connector in the machine which has continuity to the centre electrode, I can see a thicker red wire behind the nozzle but can't find what it connects to.
Here are a few images of the torch
Yes you did, but i read it to mean there was a plastic ring that you lost, whereas this uses the cup to connect them. very similar though.I did mention those 2 contacts in post 11
So which model Cebora should i look for consumables for? Don't want to buy parts that end up not fitting.As said, that looks exactly like a Cebora machine.
Are you pressing the torch down when pulling the trigger? The two pins in torch head should be contacted by brass ring in nozzle holder while pulling the trigger switch to initiate pilot arc.
Also tired electrodes can occasionally go dead and refuse to arc at all! It's well worth trying a new tip before proceeding with any other fault finding.
Can you post a clear picture of the part which lists the input voltages.
How does the electrode fit into the torch ?So which model Cebora should i look for consumables for? Don't want to buy parts that end up not fitting.
Yes have tried holding it still on the plate while pressing button, tried dragging it, tapping it, nothing.
I did think I had found the problem yesterday, that red wire I asked about, I got the torch apart yesterday and that red wire connects to the tip except mine was unplugged, with it connected it still didn't arc!
It threads in, then the spreader and nozzle which are held together by the cupHow does the electrode fit into the torch ?
some are held in place when you put it all together, and others thread in separately.
Thread the tip in, and then pull & push it.How does the electrode fit into the torch ?
