ajlelectronics
- Gloucester, England
Clarke international don't have them, L&S can't help and searches for the Ruixing 124 have drawn a blank.
I'd be pulling apart a cheap click type bio and finding the cartridge return spring for a bit of fettling....![]()
Did you note how many turns out on the adjustment screw when you removed it?I have the updated throttle link on order, so not so concerned about that. I am just baffled about how I adjust the fuel mixture when I can't access it.
If you did, preset it back to that before install.
(If you didn't note the settings try 1.5 turns out from fully seated - it's a pretty common setting - and a plug electrode check for colour after a period of running should let you know if it's ok)
Crankers Wamp?I will investigate further when my arm isn't so sore from pulling!
Give it a good whiff of brake cleaner up the air intake before you give it another few pulls - see if it fires?
It might give you a couple of clues to follow?
(Also technique.... pull the starter rope slowly out till its on compression first, let the rope back home, then a good whiff, and then a long steady, strong pull, not a snatch).
Have you replaced the fuel lines as well?
