That's not bad for a beginner imo. Penetration is ok. It's certainly better than a lot of MOT welding I've seen.Front/back/profile
Trigger on for a little longer so I got penetration but I think I rushed too much so it's far from straight....
Yes I was using my left hand to steady my trigger hard. I think I need to take my time to get the wire on the joint properly. I was also trying to ignore light coming in from behind my head (round my mask) I think I saw a post on here somewhere about wearing a hoodie or having some kind of leather neck cover to cut out light?And you using both hands? One for trigger, one near the shroud to direct and steady.
Those runs are much too long to avoid distortion on 1.2mm steel. The whole thing needs to be a series of short, overlapping tacks: 2-3mm, not 20-30mm. Even then, you need to space them out, let it cool, and be lucky!A few tack welds first then short runs of 20-30 mm at a time. I must have put too much heat in as the metal is not flat.
