Cheers much appreciatedYou been looking at my vertical up?
Yea 6013 Downhand is that on the flatLooks like 6013 rods to me. A difficult place to start.
What settings?
I'd try some 2.5 7018s and see how you get on
Everyone has to start somewhere so don't give up just yet.
Have you got the hang of downhand welding yet?
You can't beat arc time but I really really hate 6013 for anything other than a straightforward fillet.
They do leave a nice bead ripple though.
ThanksI would experiment with different amperages,welding travel speed, and rod angle, and if you're not tied to 6013, try other types of rod. Just some things to think about . At the end of the day it's only welding practice, and skill comes with time burning rods. You'll get it mate.
What rods ? 6013 ?
Will do cheersWhat amperage are you using? Your welds look cold. Also are you running in straight lines or weaving a bit. What ever the amperage range on the box is I would start at the lowest setting and gradually work higher taking note of what happens to the weld, also just let the rod burn in straight lines at first to get a feeling of how the rod wants to burn.
Thanx will have agoStart with a vertical fillet. It is easier. Vertical butt should be two pieces with a bevel. The bevel will help you and guide your rod some
Have you mastered the horizontal flat position yet?
There are a handful of AC compatible ones.As I think as has been said 7018's need DC.
they are great for stirring paintLooks like 6013 rods to me. A difficult place to start.
What settings?
I use them for everything ,,, when you get used to them they are grand ,,,they are great for stirring paint
Many thanks Hyes its a 16 amp plug...get a 16 amp socket from screw fix, a length of decent flex, i think 2.5 is the largest you can fit, and a heavy duty 13 amp plug (because they have a larger opening for the thicker cable)...
make sure you have a 13amp fuse in the standard plug and be ready to blow fuses if you try to run it too high...but on a 2.5mm rod you should be fine.
i run all my welders off those blue plugs as it stops people wanting to borrow them, but i have a fly lead for when im working at someone elses house.
Just don't waste your time at Screwfix if you're after a proper heavy duty 13 amp plug - their "heavy duty" plugs only take a 1.5.mm wire. what you want is something like this, that will actually take a 2.5 mm cable.yes its a 16 amp plug...get a 16 amp socket from screw fix, a length of decent flex, i think 2.5 is the largest you can fit, and a heavy duty 13 amp plug (because they have a larger opening for the thicker cable)...
I'm not saying they don't exist...Is there such a thing as a 13A plug that can fit 4mm wire?
Yes, the high-end audio world has them, at a price:Is there such a thing as a 13A plug that can fit 4mm wire?
