MattF
- South Yorkshire
I've obviously no idea what it is yet, but you've added brass. That's good enough for me.
All to common, sadly. If its running it can bite you. Switch it off! Makes me cringe when I see my neighbour fiddling with kit while its running.The guy who supplies hay to the stables nearly lost his arm a couple of years ago, a common jam up so he jumps off the tractor leaving the PTO running "I've done this countless times before" this time it bit him, he was off work for a few months and still has the nasty scars as proof.
Transporting the wrong kind of bricksFriday an easy job to move some spare driveway paving bricks.
Two careful trips about 8 miles away.
Sounds painful..Replaced the NVG Mount on my helmet
Pressure cooker?
I picked up a used jet wash cheap. The guy I got it from said the gun was leaking. I was hoping it’d be a seal or o-ring.
Further investigation revealed it was the plastic valve body cracked.
The parts aren’t available separately and new guns are £35 and the cracking valves are common place.
I need to practice machining so I thought I’d have a go at making one out of brass.
Some round brass stock was all I had to I set to it.
The old and the new
Fitted. I’ll test it tomorrow to see if it works.
Thanks, will see if it even works later today.Nice work.![]()
Yes, Spot on !Thanks, will see if it even works later today.
What’s the trials bike?So technically I started this last month but I did finish the last couple of tubes on this today.
We've all got eyes like certain caravan travellers.What’s the trials bike?
Its ok I noticed it too!We've all got eyes like certain caravan travellers.![]()
It’s a Fantic 200. My Dad likes falling off it on the weekends.What’s the trials bike?
