Rather than cutting to full depth in one pass, several shallow passes quickly moving along would minimalize heat transfer.For 36m (72m if cutting with a slitting disc) I'd be inclined to try a wall chaser fitted with a pair of Lenox MetalMax diamond blades for metal (or the equivalent from another manufacturer). They are slower-cutting than normal thin slitting disks, but you don't need to deal with them wearing down significantly. Normal thin discs might work ok, but I'd expect the diamond ones to work better over several hours. I'd expect it to need some sort of guide arrangement lashing up to keep centred on the box-section and cutting straight.
It seems like the sort of job you'd want to fob off on a ginger scouse apprentice.
I don't know how long it'll actually take but at a wild guess of progress at 1mm per second, 36m of cut would be 10 hours of a job.
I'd also at least half-expect to need to follow behind and weld on the brackets to keep the gap from spreading and I'd be hoping there's no serious twist or warp to contend with.
I hope the company has a cast iron contract for these works.
Is the bump in the road deliberate or did you sneeze ?Well Plasma cutter it is then:
Done a couple lengths now and it hasn't moved at all. We are going to experiment with Robin's suggestion of filling them with water, pics to follow........
It's my R-tech 50amp set.
I am surprised it hasn't moved, I was expecting it to spring open quite a bit.Well Plasma cutter it is then:
