...if only you didn't have so much stuff![]()
You have floor space, you need more stuff.Where would be the fun in that?![]()
Got a link for those rivets?These arrived yesterday.
⅛" brass rivets, to reattach the nameplate. I'll be damned if I can find the "rivets" I took out, but they weren't actually rivets anyhow. They were brass woodscrews. They must have run out of rivets when this was being assembled.
That's proper nice, and well done !Almost there now.
I'm quite chuffed with how well this machine has turned out. Couple of final little tweaks I need to do, & then I'll be able to test it.
Add a set of collet blocks, and the Wonderful World of Triangles, Squares, Hexagons and other peculiar shapes becomes routinely obtainable.
Quick to set up, and repeatable in operation....
I've got a set of 5C collet blocks, frequently used on my 'Royal' shaper.Collet block as in a collet chuck you can clamp in the vice? If so, I already have an ER40 one knocking about somewhere, due one of @Kram's Amazon bargain posts.
Managed to get the last task I needed to do, before classing it as functional, done.
Made a couple of brass screws for the toolholder housing. It's not the original housing, so they added screws to adust out a bit of sideways slop. I wasn't using the steel ones it had previously. Don't want them scoring the toolholder. I plan on making a replacement housing at some point.
The middle "screw" isn't actually doing anything. It's just there to fill the hole. The top & bottom screws are plenty to achieve the desired purpose.
