Brushed it all off afterwardsCast isnt good for the machine, very abrasive, give it-a good clean and re oil
Unfortunately just an old brake disc that was handy and insert was in the lathe at purchaseThats presumably some unknown cast iron material, so difficult to judge. I wouldnt be too disappointed with that, but it would be easier to judge with a known grade of steel and a known insert type.
Live and learni wouldnt be machining cast without covering the bed up
It was literally the advice in post #4...Live and learn![]()
Forgot discs were cast, was the nearest suitably shaped piece of metal that didn't run fast enough, and something was getting made into chips asap!It was literally the advice in post #4...
Will look at handle and find a straight edgePut a straight edge across the disc to see if it's flat or very slightly concave (you don't want it to be convex). Put a washer or shim under your toolpost handle, it looks like it's pointing towards the headstock, potentially resulting in a collision with the chuck when working close up.
It's only the outer skin of raw cast iron which is abrasive, due to sand inclusion, is it not.
Used the centre hole in the drum as it is the only machined surfacehow accurate have you clocked it up and where from![]()
That looks near enough for “ pit work”.Made my second portion of chips today.
Ignore the oopsie, didn't realise had the tool against the face then turned it the wrong way![]()
