So change "240 vac" to a fence charger....I heartily condemn this sort of thing. You never know when some innocent animal might brush against the container.
They have a used once twenty foot container where I work.
They had the option of having it sprayed inside with some anti condensation stuff, they had it done and it’s been fantastic, not one little bit of moisture any where and the coating is really thin.
whilst your clearly forgetting if that container is in direct sunlight it will expand seperating the metal from the foam as the foam shell does not expand with the metalMaybe worth reminding people what causes condensation; water vapour carried in the air touches something with high thermal conductivity which is really cold. Colder air cannot carry as much moisture so it just "condenses" out onto the colder surface.
Even a thin barrier of anything with a low thermal conductivity will prevent the air from touching it. Apart from the obvious fire risk, polystyrene is a great example. It might become literally as cold as the steel (in this case) but it cannot chill the air sufficiently for it to condense. Those fireproof expanded foam coatings would be my goto solution.
The upshot being if you can "tank" your container with anything that stops air touching the steel, there will be no condensation issues with the surfaces of the container. Same cannot be said for any cold steel objects inside it of course...
That's a good suggestion but for various reasons I've opted for a new container. I guess we'll see how it pans out.Consider buying an older but insulated one? I’ve an old site cabin from Eagle plant hire (not far from you), it’s been great, pedestrian door already and fully insulated. Lights and electrics also already done. Mines on 4 pads I installed.
Damn yes, then come and do mine, it's on the list for this year.Getting a one-trip 20' container in the next few days. I may have a few questions over the next few days and weeks as the "project" develops.
The container will be sited on a concrete hardstanding which has a slope for run off. The supplier says they will provide materials for levelling. I think this will be offcuts of ply or whatever they have. Shall I use my own, and what's recommended for relatively long term use? I presume DPM is pointless.
I will cut and fit a personnel door. This could be on the far end (opposite cargo doors) or side. Structurally, is there any preference? I'm looking at Latham's steel doors. I will fab and weld in my own frame.
Lock for the cargo doors. Any recommendations? Several recent break ins in the local area. I'm tempted to fit a security bar across the inside of the cargo doors rather than spend OTT on a huge lock.
I want to fit an alarm system. I will consider a second hand system or make my own. It should be simple and loud.
The container will be off grid and used for storage only. It's not a workshop. I have several spare 400W solar panels and will be looking for a battery, solar charge controller (viktron?) and lights in due course.
+1 for this ...get the science right and there really shouldn't be too many issues.Maybe worth reminding people what causes condensation;
Good to hear a positive experience.I bought my first 40 foot hi-cube to store household effects while we rebuilt the house. It was levelled in the farm yard and I installed a builders type dehumidifier controlled by a humidistat and plumbed to the outside. I was amazed by the ammount of condensate it pulled out of the air in the container. It wasn't being opened very often and it had the four very small high level vents which presumably contributed a bit. We never had any issue with dampness.
I've still got the humidistat mounted on a board if you want it.
I'll give that some thought when fitting the solar panels.Putting a roof on the top helps prevent roof leaks. It seems to be where they fail first. We had an insulated container with our furniture in it for 15 months of renos and no issues with condensation damage.
I dont think single use ones are.The container will be supplied with a lock cover welded on (and painted).
I had assumed all containers were made from cor-ten steel.
