I must admit One of those would be nice but when I made an off hand comment about the randomness of seeing a plasma cutter in Lidl the other day to her she shot me down so fast I definitely decided it was probably not the best idea to go looking for a proper one! Especially that Rtech one thats in the for sale section!20 posts in and nobody has mentioned a plasma cutter yet? You lot are slipping…
Slitting discs in a grinder are a game changer though!
Something like a Donkey saw I agree would be awesome but operating out of a wide single garage that already houses a Cabinet saw, 5' x 3' work bench, Band saw, Mitre saw, Thickneser, Router table and a 4' x 4' CNC router I'm not exactly overrun with spare space. Hence looking for a handheld option.Donkey saw was high on my list, but it needs room to work. The band saw I bought and modified to cut metal is heaven to use. Thin 4.5 inch discs are messy still, but I've used a lot of them. Vice and hacksaw when I was young and skint...
Here are the blades, what is your saw rpm ?Just to add another option.
I already own this
Is there a blade that'll work in this for cutting steel, or does it spin too fast?
I've never tried it - but why would that be ? (I hate blunt hacksaws)In an extensive list of methods for cutting box section, a plasma cutter would be last, even below a blunt hacksaw.
Sorry to hijack the thread but tell me more! Might need that for my big 3 phase 60amp plasma when I finally finish off my CNC plasma cutter.
A lot easier to take the saw to the work - especially on long pieces!+1 for the mini portable band saws...cutting with angle grinders gets old quick!
I have the Scheppach mbs1200...will eventually make it a table for it too but that's for a future project.
Interesting thank you.I've got one of the DCS553Z metal-cutting circular saws and for me it sits there in the category of "one of the best tools I ever bought".
Yes, you can do the same thing with a slitting disc in the angle grinder, but it's dusty and relatively slow and it chews through discs (especially if you're doing relatively deep cuts where a reduced diameter disc doesn't help).
The Makita saw cuts amazingly quickly (I used it to cut some 6 mm steel bar recently and it went through it at the rate I'd expect a normal circular saw to go through a bit of hardwood) and catches most of the swarf its little hopper thing, making for a very easy clean-up. It's also really quick and easy (with a simple jig made from two bits of wood screwed together) to get precisely square (or mitred, with a similar jig) cuts in exactly the right place on box section or sheet.
Is it an essential tool? No, of course not. Would I ever sell it? Not a chance.
I wasnt knocking it for one minute. It was more an unexpected thing to find. Yes I'm used to seeing the Parkside stuff in there when I occasionally visit lidl but it wouldnt occur to me they would sell a plasma cutter! It just seemed a bit too specialist compared to the usual gardening tools and drills and saws etc.
Yep, any sort of square does the job perfectly well. I just like the fact that the fence gets cut by the saw and hence it guarantees you'll always cut in the right place. Having a fairly big bit of plywood helps as well: I rarely bother to clamp it - there isn't a lot of lateral force when using the DCS553, so it's very easy to hold the fence in the right place.Interesting thank you.
I must admit the videos I've found on YouTube doing reviews did seem to indicate it would be a good buy but until you actually try it you never really know.
The jig you've made and linked to I normally just use a framing square to do the same thing although the ability to clamp it in place and then make the cut would ensure it is in precisely the right place.
...when using the DCS553...
