oilcooled :)
Pipe Welder, Mechanical engineer
- Ireland
A 9 inch grinder and 4.5 inch grinder will make the best tradesman out of a man. Bandsaw is best, but alot of fellas that learn with bandsaws have no eye in there head.
Thats fine. I'm unlikely to spend much time with thin stuff anymore. I've done my time trying to weld cars. not fun!Just for completeness, to give the OP a round picture, should we say that this type of saw is not so great on thin sheet? I mention it as in the top post, he says he comes from a woodworking background, where a circular saw will cut anything from veneer to double its full depth.
What do you mean by "thin sheet"? I use it to cut 0.8mm steel sheet quite often.Just for completeness, to give the OP a round picture, should we say that this type of saw is not so great on thin sheet? I mention it as in the top post, he says he comes from a woodworking background, where a circular saw will cut anything from veneer to double its full depth.
As an old boilermaker once told me:I'm with @Morris
I have all the tools mentioned so far for cutting steel.
All have their place but for a one off job I'd just use a 4 1/2 inch grinder and slitting discs.
The beauty of steel, unlike wood, is if the joint isn't perfect you can fill the gaps with the welder.
Fair enough you can't fill inch gaps (well you could) but in practice it's easy to get close enough with a grinder and a mm or two off won't make much difference.
