@gaz1 is that your shaper and if so does it perform well?look into perfecto shaper that mechanism can be used with ours as the head base slide stays still
Canadian Armed forces, pre NATO.Cleaned up the slide.
Found this stamp on it.
Anyone any ideas? @The_Yellow_Ardvark?
The N, guess, as it is from Canadian stores.Cheers.What does the N stand for; Navy? Which year did they become part of NATO?
It makes a surface flat by moving a fixed cutter over the work and then the workpiece will move over incrementally. It was used alot back in the day for doing ways and tops on machines.Can I ask what a Shaper does please?
(I never heard of one, never seen one, and interested, that's all)
Ah ok, thanksIt makes a surface flat by moving a fixed cutter over the work and then the workpiece will move over incrementally. It was used alot back in the day for doing ways and tops on machines.
.the before and after should be very satisfying.
Just need to fettle all the nuts, bolts & screws, & then I should be starting reassembly.
