I think that's too big.Like THIS?
I think so Robin but I am going to go need take a look as there were four rows of pins, nine per row?
I will order one anyway but I am pretty cross with myself at the moment, I put the plug "somewhere safe"![]()
You'll need a 12V version..Well, I am learning the machine now, I have a little bit of code that just might make something if I let it but that can wait, I was warned by @m_c that the switch was marginal at best and he was dead right it started to arc so I replaced it, I have it switching just 12 volts now, which in turn enables a relay which supplies the full 240v and it works just great. The only snag is it doesn't light up anymore :-(
This is the wiring diagram for the switch, does anyone here have any idea how I can make it light up? I have simply used the centre and lower right hand terminals to supply the 12volts.
I intend this switch to be the on/off but I am looking for something a bit substantial to isolate the mains. No good just flicking the wall switch on and off!
If anyone has any suggestions for a main isolator switch I would be very grateful.
Alternatively you could get green and red 22mm buttons, and have dedicated On/Off buttons.
