The 8.5kw heater runs in my garage at full output. Not sure how much fuel it actually uses but I would need to refill once a day. When it was zero degrees last week, I managed to raise the temperature from 0C to 7.5C after a couple of hours. If I insulated the garage, it would probably make a big improvement. My choice would be burn more fuel or electric as the cost is no issue to me for occasion use.how much fuel does the small diesel heater use ( 4-5kw max )
and how much does the unit cost
say you bought 2 of them instead and doubled your fuel
@fizzy
Electric 23p per kw/hKerosene 4p per kw/hNo contest!
A 25L tank lasts about 50 hours. Kero is about 50p per litre so 25p per hour v almost 90p for electric.
The point I am trying to make, is that being cheaper is just one of many considerations. Being cheaper doesn't make it better for all circumstances, as we all have slightly different requirements. The solar solutions look great if you're going to pay 10k for the initial solar panel installation and then want the fuss of home-brewing your storage heater. What is better for me is buying a 15kw heater with no messing, installation, or development costs and just paying for the additional cost of electricity. I wonder if the storage heater boxes full of bricks still exist; they were popular when I was growing up in the 70s. I think it was called super saver 7 or something like that. many were activated by a sub audible tone from radio 4 long wave.if you think electric is better dont its one of the dearest
but if im forced down the electric side of it, i will go down the sand battery side of it
as its storage whilst also outputting heat when no power is there and solar can be used with it as well
The cost of running the fan is low compared to the cost of running the heating part of the system. Although yes will still be consuming grid power.Running an indirect gas powrmatic in the workshop, when in use that still has a big fan running, not sure what the fan draws. Heating rarely gets used these days now it’s properly insulated.
Bob
As Gaz has mentioned these heaters only put out 4kw. Electric heating 5x the price.It's not "no contest" the running cost is just a consideration when buying a heater. I would happily pay the extra for the convenience of electricity, no mess, and instant heating, unlike fuel heaters. Unfortinately I dont have the electrical capacity to run a large enough electrical heater in my home garage. hence the 8.5kw diesel. At work, I run a 15kw 3-phase electric heater, and it is great for occasional use.
how old is your first chinese diesel heater fizzyAs Gaz has mentioned these heaters only put out 4kw. Electric heating 5x the price.
I've got a 20kw indirect heater, but it rarely gets used now.
Good for getting the workshop up to temperature fairly quickly, but the big problem is it's either on or off, so you regularly go from sweating to freezing, plus it's fairly noisy when on.
Plus venting the exhaust outside, you lose a fair bit of heat out the exhaust.
Personally, since getting a single 4/5kw Chinese heater, and installing an Afterburner (+ compatible ECU), I just turn that on before I head out to the workshop. I can even switch it on remotely before leaving work.
I do have all the bits so I can build a couple proper mounts, and mount two of them more central (current one is at one end, so the far away end doesn't get much heat), but provided it's above 0degC outside, the single one makes the workshop tolerable.
My oldest one had about 5000 hours on it. When i was really ill in hospital a mate of mine refilled the 40 litre tank for me. With 30L of industrial bleachhow old is your first chinese diesel heater fizzy
as i presume its well over 5 years now and been run hard as that keeps them clean instead of tick over heating
so lets say 5 years at 100.00 for the unit so thats 20.00 a year + power unit as well
its alot better than many may think
 I wouldn't leave it unattended either. I won't even let the forklift charge overnight.I hear yah. Problem is I have £50k of stuff / cars in the garage so I'm not risking a Chinese diesel heater running unattended. Otherwise with a smaller and better insulated garage- yes afterburner control would be a great solution.
Provided that they're installed sensibly, and make sure nothing flammable can get near the exhaust, the fire risk isn't an issue.I hear yah. Problem is I have £50k of stuff / cars in the garage so I'm not risking a Chinese diesel heater running unattended. Otherwise with a smaller and better insulated garage- yes afterburner control would be a great solution.
I wish they did a bigger one. Eberspacher do a proper 8kw one. For about £3000These Chinese diesel heaters which are great for camper vans and are a copy of the eberspacher heaters in trucks are fine for a small garage, I’ve thought about buying one for my workshop to keep it warm after the big heater has dealt with cold, haven’t got round to trying one though, have a feeling that 262 cubic metres of uninsulated space might be a bit ambitious, but maybe 2 would do the job.
