AVI_8
- Prestwick
Ooh. 2 chinese heaters would get about that for £300 quid, different quality no doubt Though fizzy.I wish they did a bigger one. Eberspacher do a proper 8kw one. For about £3000![]()
Well i have had over 5000 hours out of a cheap Chinese one so can't complain. Current 2 we use have been running 8 hours a day for 2 years now. Save me about £400 a month in electricity.Ooh. 2 chinese heaters would get about that for £300 quid, different quality no doubt Though fizzy.
Yes I can definately see the benefit, first year I built my workshop I had 2 x 3 kw heaters running, £2 per hour, they had practically no effect at all when it’s freezing, a big heater to blast the area, then a couple of these wee eberspacher clones is the way to go in a larger area.Well i have had over 5000 hours out of a cheap Chinese one so can't complain. Current 2 we use have been running 8 hours a day for 2 years now. Save me about £400 a month in electricity.
I’m paying almost double what you quoted for kerosine, but that’s filling a 25L container, I’m guessing you have an oil burner for your home heating, small volumes at least in Scotland is very expensive, no cheaper than pump diesel.I've been using a military tent heater for a few months now. I changed the flue from the original to a 6" because thats where alot of heat gets wasted. I altered the burner settings to allow the burner to run on a lower setting. It uses about 25l of kerosene a week at 60p a ltr. Thats on tickover, I turn it up when I go in. My shed is 75m with lots of machines. It helps stop the rust. I ran it continuously for a month and then took the burner to bits. There was very little soot build up.
Scottish are rip off merchants. Rural garages in Wales charge around 85p a litre. Still too expensive.I’m paying almost double what you quoted for kerosine, but that’s filling a 25L container, I’m guessing you have an oil burner for your home heating, small volumes at least in Scotland is very expensive, no cheaper than pump diesel.
yet they still havent learnt there lessonI wish they did a bigger one. Eberspacher do a proper 8kw one. For about £3000![]()
Every British ambulance is fitted with an Eberspacher or Webasto. Every lorry. These people don't care about paying £1500 for something. Not their money.yet they still havent learnt there lesson
otherwise we would be seeing eberspacher heaters within loads of sheds instead of the chinese ones we are installing now
No we use gas and woodburner in the hoose. Kero is from local fuel merchants who deliver my ovoids. They have a metered kerosene pump, you just bring your barrels or pay a deposit for theirs. At first I just got a couple of jerry cans and was surprised at the price. Then got 10, 25ltr barrels to get filled.I’m paying almost double what you quoted for kerosine, but that’s filling a 25L container, I’m guessing you have an oil burner for your home heating, small volumes at least in Scotland is very expensive, no cheaper than pump diesel.
I think my comment was more on heating capacity and that indirect 20kw heater are available and relatively cheap. The heater I currently have, regardless of whether it is a 5 or 8.5kw, only raises the temperature in my workshop by 5-7 degrees. This could be improved by installing some insulation, but having 20kw should make a big difference and would be more convenient for my usage case. I obviously have no idea how good these IDE20 are and if they are actually 20kw. I know many people enjoy homebrewing low-cost solutions, but for me, it is purely about convenience. If you only operate the heater for a few hours a week, the fuel cost is not really a significant consideration for me. Everyone has different circumstances, and the best type of heating varies depending on those unique circumstances.If you don't want to leave a diesel/kero heater running unattended then put it outside. Significantly reduces the risk. The combustion intake and combustion exhaust should go outside, so you'd only need to route an intake for the heating air and then the heating air exhaust through the wall. Plenty of people have done this building little boxes on the side of the garage wall. You could even run two of 8kw ones o (iirc 5kw actual) on a bigger shared fuel tank.
Please provide an update once you have the new heater up and running be nice to have your feedback regards this equipmentThis would be best installed outside in a small weather proof enclosure and pipe the heat output through the masonry wall and onto a louvre?
Only concern as such would be bringing in external atmosphere humidity (At certain times in winter / spring) to condense on the cars but maybe any vapours like that would go out the exhaust so no issue?
Having one pipe in does also have the advantage of positive input ventilation as such so would help counteract any small incoming draughts in use.
Buy an oil tank and get it delivered as if you have an oil boiler!I’m paying almost double what you quoted for kerosine, but that’s filling a 25L container, I’m guessing you have an oil burner for your home heating, small volumes at least in Scotland is very expensive, no cheaper than pump diesel.
