My global employer tell me to do things too and they're not always necessarily based on sound Engineering judgement either.The difference is, mine is not an opinion, it's hard fact from vehicle manufacturers whose products I have been trained to, and paid to work on - including Mercedes-Benz, many to Master Tech, some to Regional tech level.
Workshop instructions contain the details, procedures, tools and measurements required to perform a task correctly. There is no 'I'll do it the way I think best', the devil is in the detail, if it's not done to the work instructions, it's not done correctly. Fact.
Service procedures are written unambiguously because you have to stipulate a procedure that even the lowest common denominator can follow without having to think. Engineers often disagree with service procedures and sometimes the account managers win.
I service my own cars and for sure I will continue to grease the contact points where I see fit.That looks very much like the grease for the pan. roof runners - yep, just checked the part number on webparts - synthetic grease, WIS lists it for pan roof service.
The only other references are to 'wheel bearing grease (brake paste)' but again, no reference in WIS to applying to braking components.
There are references to caliper slide grease A 000 989 98 00 'lubricating paste' and storage greases.
I'd suggest you don't use any more of that pan. roof grease on brake pads, it has a very low melting point.
Those discs are well lipped and don't look to be six months old to me, likely the pads have been riding on the edges allowing the discs to corrode - possibly the calipers were not cleaned properly either but i'd be checking those discs for min. thickness as they look too worn to me - unless it's another of your 'gotcha' photos?
But yer, whatever you want to do on your own cars, I have an employer and customers insurers that require the job to be done to manufacturers specifications.
True, at least you only have your own insurers (and any third parties) to explain your actions to if it all goes Pete Tong.The guy did high miles so there is probably 5 or 10k miles on them in that time yes. Pads have about 10 mm material on em still. Anyways good to hear your opinion on the matter too as a garage employee. At the end of the day it's up to the individual to decide what's works best for them in their circumstances.
There are of course other environmental factors which could impact brakes.
The use of caustic / acidic wheel cleaners can of course accelerate corrosion. This could also wash out any pad lubricant.
Whilst most people won't bother, I do think it's important to remove brake pads every year or 2 regardless of mileage and make sure they are moving correctly. Brake fluid also has a service interval so this is a good time to check the pads too.
And that was my point, they don't come fitted out of the factory with anything but dry mounting shims and (sometimes) sticky pads and / or dense insulating pads, so why do people 'know better' and start adding grease etc., loaded or not. The only parts that are greased are the caliper slide pins and that is a specified grease, not 'whatever grandad used'.
Show me any manufacturers workshop manual where it states 'The contact points of the pad VS caliper should have a small amount of brake grease applied. Lube between pistons and back of pad' and I'll buy the lube for you myself.
Thanks, that illustrates the point nicely "Old Defender workshop manual" I'm presuming 1980's or 1990's? - that's before modern materials and designs of braking components were used for most vehicles, so it really does reinforce the 'because that's the way we always used to do it' mindset.
