Memmeddu
- Italia Sardegna
Available over here.clean any oil of em and spray with cillit bang it will remove rust no probsi bead blast all my rusty stuff. comes up like new
So if it was serious I can try that
yep you get it in a spray bottle. just stick them all in a dish and spray them a few times and wash it off . no kid it works https://www.google.co.uk/search?q=d...DDfEFsUiMS70wDT6SBwIzMKAHw8MB&sclient=gws-wizAvailable over here.
This would because one of my favorite cleaning productsyep you get it in a spray bottle. just stick them all in a dish and spray them a few times and wash it off . no kid it works https://www.google.co.uk/search?q=d...DDfEFsUiMS70wDT6SBwIzMKAHw8MB&sclient=gws-wiz
Never had that problem.Won't they go black? Everything I have done in evaporated has gone black.
I'd be happier with that than acid/electrolysis.What about an ultrasonic machine?
I've found a little problem.yep you get it in a spray bottle. just stick them all in a dish and spray them a few times and wash it off . no kid it works https://www.google.co.uk/search?q=d...DDfEFsUiMS70wDT6SBwIzMKAHw8MB&sclient=gws-wiz
If you could find the active ingredient in it you might be able to buy it on its own or in another product.I've found a little problem.
Apparently European parliament banned cillit bang because it's unknown formula and health hazzardous potential...
Anyways I can get some from Amazon quite expensive but I've asked around in those days and it's a good product and worth the money.
Now I'm intended to buy a 6x750ml pack.
Are you able to show me the exact product I need to buy.
I think it's the lime scale removal with the orange sprayer but I'll wait for your answer
What's your method for electrolysis of numerous small objects like that? I've made a bath with carbon electrodes all round, but only tried it on single large things suspended from the top.
Do not use stainless as an electrolysis anode as you'll be making hexavailent chrome and poisoning yourself.Cast iron anodes, (old sash weights are a good source), & a metal mesh basket holding/containing the taps & dies.
That mesh bucket looks more like stainless than cast iron?I know.Never did, never will.
I found cast iron the best general all-rounder. Lasts much longer than steel, & close enough in type to most things going into the vat.
Really need to get a vat set up here. Not had one running since I was at the previous place.
The liquid goes black as it does its job.
If you leave the item in Evaporust in an Ultrassonic cleaner long enough it will remove paint.
I am not a fan of the spray on Evaporust gel.
Rust converters generally make ferrous metals go black but not in Evaporust in my experience, so far I have used 5 litres.
The rusty parts go on the annode, + positive connection, where rust and then metal will be removed.
You can use anything on the cathode and it will be plated with whatever ions are floating about in solution. If your taps are on the cathode, they will be coated in mess.
That's been my experience with evaporust also..Interesting.
Normally i use deox-c, but bought some evaporust to try out. Just a few bolts and washers. All went black. Took 3 days to get the rust off too. And cleaned the each day to "assist it" as literally nothing was happening.
Looking deeper, i think the formula for UK/EU is different as different part numbers. So far, very unimpressed.
Mixed up another batch of deox-c tonight to run a direct comparison.
