I'd have gone with a CB radio look. Mic socket one side, dial the other, display in the centre.
I like that version.
Maybe you have said before but why not use the electronics part of fusion. I have never used it so it may be rubbish but I think it is Eagle that was supposedly quite good.
I don't have experience with EasyEDA and Fusion but with KiCAD and inventor the issue is that STL files have no way of adding constraints as far as I know so if you happen to explode or move one of the inner components of the PCB assembly all hell breaks loose.Still working on this project. It's getting more and more involved and I also have strange things going on. I suspect that the PCB program is corrupting its export file in two out of every three writes. When it gets into Fusion, all the parts have flown off in various directions and the main PCB is at a jaunty angle!
I use Kicad and export as a step file into Fusion. I've not had the problems but doesn't mean anything! Is easyEDA web based these days?
I don't mind having a play with it tomorrow if you need a second opinion?
I find things like this slightly ridiculous in this day and age but so much crap is built in for advertising etc. An example is I'm so glad I found a way to revert Adobe Reader back to an old style interface and get rid of the so called artificial insemination assistant. Datasheets and the like have enough mistakes in them as they are without AI splurging all over it.I do have 32Gb RAM though maybe EasyEA is trying to buffer it online.
On the Fusion side of things:Still working on this project. It's getting more and more involved and I also have strange things going on. I suspect that the PCB program is corrupting its export file in two out of every three writes. When it gets into Fusion, all the parts have flown off in various directions and the main PCB is at a jaunty angle!
Use "Joints" to position components NOT "Moves"
Join components together, even if they are drawn in place.
Make sure that all of your sketches are fully constrained (padlock icon in the tree on the left / all lines in the sketch will be black and NOT pale blue).
If you don't do these things, there's always the chance that the whole model will spring apart and reassemble itself in some unintended configuration (which can be a *lot* of work to recover from).
(I don't know how/if constraints are exported to the PCB program.)
Simply moving components into place and not constraining them usually does exactly what you are experiencing
