Yes, exactly what was happening. It was trying to be a universal joint, and very hard to set up single-handed. Very little jaw contact.That's called walking, the part is walking out of the chuck.
Either you haven't got the part perfectly centred in the steady or the steady is not true with the axis of rotation.
Looks like a cracking jobI found 3 small bearings in a drawer today which I forgot I had (the bearings, not the drawer).
Then I had a bit of a brainwave and decided to use them for ball bearing fingers for the South Bend steady rest.
So I cut of some bits of 12x50 flat bar and milled them square and to size.
Nice sliding fit in the steady and no wiggle.
Tomorrow I will drill some holes, mill some slots and turn some pins.View attachment 480698View attachment 480699View attachment 480700View attachment 480701
I have seen taperlock bushes sit proud in the past, and I always just put it down to tolerance issues.Something i've not had to do before.
Machine a worn out flange for a taper lock. 1108-28.
Went fine, if working to the fenner document, diameter at the large end should be 38.2-38.28mm.
I made this 38.2 but it still sits somewhat proud of the flange.
Won't matter for this application however but something i'd like to clarify for future use.
View attachment 480726 View attachment 480728 View attachment 480729
It depends on the shaft diameter tolerance as well...Something i've not had to do before.
