zzr1200
Working at 650 ft on open steel work.
- Glapwell, Chesterfield, Derbyshire, UK
I ordered 2 of these from Vevor, 1 for the new plasma cutter to go with the table build, the other one to use solely for the carbon air-arc torch, hopefully with double water filter traps I'll have clean/dry air. the fixing bracket appear strong and can be reversed so the in/out ports can be changed if required.
www.vevor.co.uk
![20250105_090233[1].jpg 20250105_090233[1].jpg](https://www.mig-welding.co.uk/forum/data/attachments/475/475795-a89098cb6577027967cbcfab940dd943.jpg?hash=qJCYy2V3An)
VEVOR Air Compressor Filter Regulator, 3/8" NPT 5μm Air Compressor Water Separator, Semi-Auto Drain Air Drying System with Brass Filter Element, Double Stage, 7.5-125PSI Pressure Regulator, Poly Bowl | VEVOR UK
VEVOR Air Compressor Filter Regulator offers precise pressure control, dual 5μm brass filters for clean air, and a semi-auto drain system to prevent damage to your tools.
