Dr.Al
- Gloucestershire, UK
I've lost my mojo a bit at the moment and I'm not managing to do much each day. Not sure why; these things happen now and again. Anyway I am managing the odd bit. The sheets I prepared yesterday went into a citric acid bath last night in the optimistic hope that it would help with the rust and save a bit of wire brush work:
They've been in there for about 18 hours so far without much happening, but I'm not that surprised as it's relatively cold outside and that definitely affects how well the acid works. If there isn't much progress in the next day or so I'll probably give up and just deal with it with a wire brush.
What I did manage to do today was make a tiny bit more progress with the control cabinet frame. I drilled some 11 mm holes in the ends of the two outer frames:
The frames are two big for the pillar drill so I used a cordless drill instead. I also drilled the first couple of what will end up being quite a few countersunk holes for earth studs so that I can make sure every bit of metalwork is properly earthed:
The 11 mm holes were for some M8 weld nuts (sold as cylindrical coupling nuts), which are a tight fit (needing gentle mallet-based persuasion) in the 11 mm holes. They get whacked into place and then weldedthe lazy way autogenously (i.e. without filler) in place.
I decided I'd then have a go at my first bullet hinge. I'd never used these before and I was quite concerned that the inevitable movement that happens during welding would result in the two hinges having misaligned axes and hence the door not hinging properly.
To try to align the hinges, I clamped the frame and the door in place with some feeler gauge stock giving a gap all the way round (even at the top and bottom and a bit wider at the opening edge vs the hinge edge). I then clamped a steel rule to the door at what seemed like the right distance from the edge to try to get the hinges aligned and parallel with the edge.
I couldn't think of a good way of clamping the hinges in place (partly because I'd clamped the door frame in place too far from the edge of my bench to give a good choice of clamps) so I just used a Welder's Third Hand to keep it in place...
... while applying a couple of tack welds to each piece:
After releasing all the clamps, a quick check showed that the hinges still worked as expected so I welded all the way along each joint:
Once I'd had some lunch and let it cool down, I could try it out and it works... not perfectly, but much better than I expected.
The loose bullet hinges slide apart extremely easily. In theory, it should be similarly easy to lift the door off the hinges but they're much too stiff for that now (due, presumably, to slight misalignment). However, a few taps with a mallet separates them, which I think is good enough.
The door opens easily (and closes again!) but doesn't fully close naturally. If you lean it back so the door swings shut the door will stop with this much of a gap:
Light pressure overcomes that last bit of springiness and the door can be shut, so with a latch of some sort (I haven't even started to think about that yet!) it should shut fine:
The maximum amount you can open the door is, as you'd expect, the point where the two bits of angle iron hit each other:
Overall I'm really pleased with that as my first attempt to weld a hinge in place. It would be nice to know what I should do differently to get the hinges to align perfectly (for easier removal of the door), but they work remarkably well as hinges given the fact they can't be perfectly aligned (or else it would be easy to remove the door).
