Dr.Al
- Gloucestershire, UK
For my impending heat treatment oven build, I'm going to be making the control cabinet from scratch (rather than being sensible and buying a project box).
That's going to involve cutting lots of holes in the sheet metal (probably steel, but could be aluminium as I think I have some of each) for the various things to poke through. There will be quite a few push buttons requiring 22 mm diameter circular holes and quite a few other things requiring square/rectangular holes of various sizes (the smallest being for a mains toggle switch, the largest being for a PID controller).
I've been experimenting today with ways of cutting the holes (mostly in 0.8 mm steel, but I also tried some aluminium of a couple of different thicknesses and also some 3 mm steel). I'm struggling a bit so I'm after some advice!
My initial attempt was with a Bosch holesaw in a cordless drill, but that produced a hole that was a long way off round (I won't be able to do it in the pillar drill as the sheet will be too large).
My next attempt was with a plasma cutter, which I suspect is quite a good option, but I've never got to the point that I can get a neat cut when doing anything other than a straight line. I made some simple templates, starting with a plywood one with a 28 mm hole drilled in it (the tip offset seems to be 3 mm, so a 28 mm template should give a 22 mm hole). I kept finding the tip catching (preventing me moving it smoothly) and I also find it really hard to judge how fast to move the torch. Moving it smoothly in a circle seems to be rather challenging regardless of whether the tip catches. I also tried a 3D-printed template out of curiosity - I expected it to turn into a blobby mess, but it coped remarkably well. It didn't help me produce a neat circle though!
Cutting with the plasma cutter along a simple straight edge seems okay.
I'm not sure whether the problems are down to the sheer number of variables (current, air pressure, speed of movement, whether the tip is touching the metal or raised slightly above it, ....) preventing me from figuring out how to get a good cut or whether it's just that I'm completely inept when it comes to plasma cutting.
I'd appreciate any advice on how I can get a better cut of holes for things like push buttons, mains toggle switches etc, either with the plasma cutter or with something else (that I own!)
