1) It will make minimal difference.Things have been progressing a bit slowly, but progress nevertheless. I ended up removing the upstand, packing it out and boarding, now it's time to sound deaden the alcoves.
I'll be building a separate 50mm metal stud wall spaced 20mm away from the actual wall, then stuffing rockwool in the frame, followed by 2 layers of acoustic plasterboard. I'm following the gyproc guide so it will be done by the book.
Question 1: Would I notice a difference if I opted for 2 sheets of 15mm acoustic plasterboard vs 2 sheets of 12.5mm?
Wall A will be 5mm below the surface in relation to Wall B if I use 2 sheets of 12.5mm, or flush with Wall B if using 2 sheets of 15mm. The leading edge of Wall B (green line) has a bit of metal beading.
Question 2: Should I bring Wall A out to make it flush with Wall B and have the whole lot skimmed over, or should I leave Wall A 5mm below and have the skim meet with the level of the existing plaster on Wall B?
Question 3: Do I need to remove the metal beading on Wall B (green line) before it's skimmed or will it blend in?
well its your choice and yet i think your foolish and i will explainThings have been progressing a bit slowly, but progress nevertheless. I ended up removing the upstand, packing it out and boarding, now it's time to sound deaden the alcoves.
If there womens wardrobes theyd be good sound insulation as they be rammed fullwell its your choice and yet i think your foolish and i will explain
you loose storage space by blocking both alcoves in
ontop of that you also loose 3 double plugs by blocking the alcoves off
the size of room you have you could create a full frontal cupboard with drawers and a vanity mirror for a lady
drawers across the front of the chimney breast
double wardrobe to the right and a single wardrobe to the left a mirror and top for a vanity unit
This is very factual and very true.If there womens wardrobes theyd be good sound insulation as they be rammed full
it depends on age of the property whilst older propertys was built 3/4 bricks wide newer propertys are not as they are only 2 or 3 bricks wideI was looking at decoupling the acoustic plasterboard with a stud frame and infill with absorbing insulation. It was going to be a lot of work and I'd lose quite a bit of my room....in the end I decided a better solution would be to decouple myself by moving house!
....still looking for a new "dream" place...have been for about 5 years now!
roof timbers are massivewell its your choice and yet i think your foolish and i will explain
insulate is also sound deadening the one ive shown you seperates from the wall the way ive suggested you gain 4" insulation in the process instead of a gap and then 2-3" of insulationI'm not trying to insulate, i'm sound deadening.
That's also the conclusion I came to.I've done a lot of reading into this and an independent wall is universally accepted as the best method of sound insulation.
Dream houses are readily available. Its paying for them that is the issue!I was looking at decoupling the acoustic plasterboard with a stud frame and infill with absorbing insulation. It was going to be a lot of work and I'd lose quite a bit of my room....in the end I decided a better solution would be to decouple myself by moving house!
if your neighbours have taken down the chimney it wouldnt still affect you unless theyve striped the boundary wall of the first layer of brick due to fire damageThat's also the conclusion I came to.
The reason I decided not to bother is the neighbour has removed their chimneys...so I suspected that a lot of the sound might be coming thro the chimney on my side which the sound wall wouldn't help with.
