Brad93
- Essex, United Kingdom
I find migatronics to be like fronius machines.
Always fiddling in the background and not telling you what it's actually doing/or allowing you to change that setting.
There's a fronius at work, TransSteel 3500 i think it is. Single pulse.
If you put it in synergic it will give you a setting and usually it welds pretty poorly without trimming the voltage a fair bit and adjusting the induction.
If you put it in manual and select the same parameters the synergic has recommended and you've found a decent condition with, it's nothing alike.
So the machine must be doing something in the background you cannot see/chnage.
I've always found migatronic to be over complicated and prone to failure.
