If you're trying to run your mig at 20 amps, that might be most of the problem...20A.
I was talking about the lowest amperage to illustrate a point about the voltage trim adjustment (specifically that it's another dimensionless parameter, which indirectly adjusts the voltage via the control logic).If you're trying to run your mig at 20 amps, that might be most of the problem...
0.8 wire is only supposed to be used down to 40 amps, 0.6 down to 30 amps. Below that, you'll get instability.
I have used all 19.98 somethings of that range, trying to dial in settings that would fix my problems, and It's not creating anything like that level of voltage swing (nor should it).The only way a straight ±9.9V adjustment would make sense was if every program defaulted to something like 23V."
I'm just saying what presented parameters are. Of course, if I tried to use all +-9,9V adjustment range, then at the opposite ends it would likely weld like sh*t, but tweaking potential is still there, if you need it.
I am familiar enough with my own welder to know where the buttons are.And if you press that right side button to tweak voltage, then machine shows actual voltage during welding. No need to guess, just look at it in the screen
Burnback and Arc-Choke (i.e. inductance) settings.Lower button is for burnback or something like that, but I rarely touch that. (maybe this is your "trim" you adjust all the time?)
It might be worth me actually looking at the inductance adjustment...If you put it in synergic it will give you a setting and usually it welds pretty poorly without trimming the voltage a fair bit and adjusting the induction
This is basically my entire frustration, with what is otherwise in many ways one of the best MIG welders I've had.So the machine must be doing something in the background you cannot see/change.
The issue is less pronounced in horizontal and flat position, but it doesn't go away.will it weld nice on a bench top , same wire etc etc ,,,, if so the switch to overhead issues points at the nut on the torch needing adjusting some.
thats not the nut that needs adjusting ,,,,,I was talking about the lowest amperage to illustrate a point about the voltage trim adjustment (specifically that it's another dimensionless parameter, which indirectly adjusts the voltage via the control logic).
The voltage being displayed during welding is absolutely **Language**ing useless, because it rapidly switches back to the dimensionless "trim" number when you're not welding.
Like most people, I am not looking at my welder whilst welding, and so if the display doesn't hold, then I can't read it.
I have left them well alone for the time being...
I would generally leave it at minimum for thin metal though, which is what I would assume is the factory default setting.
When it works, it just works and you can forget you even have a welder, like you're just shooting molten metal out of your hand...
When it won't do what I want, it's extremely opaque why it won't, making it much more difficult to work out what the issue is and correct for it.
It's certainly worth adding the torch nut and other wire feed system parts to the list of things to inspect and check.
Rude!thats not the nut that needs adjusting ,,,,,![]()
then at least you know where to start looking , your actually now saying the welder isnt welding well in any position then ..... ??Rude!
But yeah, it's not something that goes away in other positions, it's just easier to deal with in those scenarios.
At lower power settings than I am accustomed to working with, it wasn't behaving like I would expect a MIG welder to...your actually now saying the welder isnt welding well in any position then ..... ??
trust me after 40 years at it , some days things just dont always add up either ,,, Im a get in hot and fast sort of welder , overhead I dont turn anything down , short arc and a good torch angle , with a good jacket mask and gloves and keep going , the major issue with mig is that its easy , and its hard . Now that sounds contradictive , but I will explain , its very easy to get results that look great and will keep most folk happy ,,, but , its also hard without experience to actually know whats going on , and whats really good and bad in real life , I worked as a weld inspector for a while both off shore and in the aircraft factorys and sometimes things are not as they look ,,, its good practice to do a quick cut and etch from time to time and actually know whats going on , especially if you move onto thicker things , or things that may be important .... many many many farmers do the whole get it in tight , no gaps , good fit thing , and thats how they make things , if its gates or fences it seldom matters , .... but watch an engineer or a welder at work and its all about gaps and weld prep. After a while you get a feel for your machine how it sounds and feels tells you a lot about whats going on , but that takes time .......... TAt lower power settings than I am accustomed to working with, it wasn't behaving like I would expect a MIG welder to...
Whilst I could make up for that with skill to a point, when I came to overhead it was a problem.
As it turns out I spent far too long assuming that it's just that mig welding sheet steel is very hard, and making the best of a bad job with the welder well out of whack.
It's now welding significantly better, after updating the software, calibrating the wire feed, and resetting the choke settings.
The whole point of me starting this thread was that it's hard for me to say what "well" for sheet metal should look like...
I have only maybe 30-40 hours of experience at welding sheet steel over the past year, vs well over a thousand hours of welding thicker material over the past 5 years.
All I knew was that at lower power settings than I am really accustomed to, it was behaving in a way that didn't make any sense based on all my experience.
