Jelly_Sheffield
Time is an illusion. Lunchtime doubly so.
- Sheffield, UK
Since getting it running I have consistently had issues with my synergic welder (Migatronic Rallymig 161i) when welding overhead, especially in thin metals (0.8mm to 1.5mm).
If set to the correct thickness or amperage on the welder it will consistently use too slow a wire feed and too high a current relative to it, causing the weld to hang down, or the wire to go into globular transfer mode (which doesn't work upside down) and constant fouling of the nozzle is an issue.
If you set it intentionally high, it will generally get ok penetration and go in ok, but even a tiny increase in arc length will cause it to suddenly increase current disproportionately high and burn through.
I'm unsure if this is something that can be easily solved with specific settings and I'm just not thinking about it correctly, or if it would be a case of developing a new program for overhead and loading it onto the welder with the SD card.
My much older synergic welder (a KME550) offers very granular manual control or fine tuning of all parameters via a bewildering array of knobs on the power supply, so I haven't faced this issue with it all.
