Arc Tourist
- Wales
I'm also awaiting Mr. Ardvark's reply MattF, but I do know from experience that Co2 leaves no residue.What's the best type as an all-rounder?
Foam will cover most incidents in a workshop.I'm also awaiting Mr. Ardvark's reply MattF, but I do know from experience that Co2 leaves no residue.![]()
To do what?and with powder you need toilet paper in the fridge
the powder effects in you breath it in with give you the runs, you will be very glad of cold loo paper.To do what?
Co2 for electric fires.
Powder is a good all rounder, but the aftermath is terrible.
Normally, Powder is best for all common causes of fire, extremely messy though.What's the best type as an all-rounder?
CO2 come in two sizes.I would always suggest putting a small CO2 and one or more huge Powder extinguishers together.
CO2 isn't great for liquid "pool fires", so if you're working with vehicles or solvents, it's worth having at least one Powder.CO2 come in two sizes.
Powders range from 1kg to 9kg or bigger.
Co2 Foam and a fire blanket i bets for a work shop.
I know, I deal with extinguishers everyday.CO2 isn't great for liquid "pool fires", so if you're working with vehicles or solvents, it's worth having at least one Powder.
If Halon was still a widely available option, I reckon that would be the best compromise.
I have been offered a KS Tools 3/4"sockets set for 70 euros+ shipping.View attachment 473465
Thought about this would take longer but 3/4" is on the way home
They say 3300Nm which is more than the onevan equivalent at 3100 but if it has 1800Nm it would be more than adequate for me.
Now a torque multiplier and big sockets set and all my Bolt unbolting needs are satisfied
My oil boiler is not firing. Motor and pump hot and trying to fire constantly for a few seconds.
I think the motor or pump may be faulty.
I bought a good used burner identical for it:
Plan is to get me going later with this replacement and repair my original one too. Having good working parts to test will be useful for sure. And if I get both serviced and working perfectly + set then I'll always have a spare to swap out. 10 minute job to swap out. One fuel hose and an electrical plug.
Totally missed the word "foam" in your reply there... It makes way more sense re-reading.I know, I deal with extinguishers everyday.
Foam is the goto for liquid pool fires.CO2 isn't great for liquid "pool fires", so if you're working with vehicles or solvents, it's worth having at least one Powder.
I have a 9ltr foam and a 2kg C02 next to the door in mine, anything that they won’t be able to put out I’d be ringing the fellas in the big red truck anyway.Foam will cover most incidents in a workshop.
If in doubt, get out.I have a 9ltr foam and a 2kg C02 next to the door in mine, anything that they won’t be able to put out I’d be ringing the fellas in the big red truck anyway.
I kept all the reducer rings for blades they have saved my bacon sever al timesToday I've not acquired a 355mm cutting disc for my Makita cutoff saw.
As I need one but I cannot find one with the 30mm hole
They are apparently out of production.
I have to try to see if the husky centering washer fits on the cutoff
Otherwise I'll have to delay a job was intended to start this morning
Sadly most foam ones are not frost proof.CO2 come in two sizes.
