northwest
- Manchester UK
Flycut?
Shell Mill.
Flycut?
Can't see any tooling marks to suggest it's a facemill or shell mill.Shell Mill.
Neither actuallyWe will await @Johnnybravo 's reply with the definitive answer, Personally I would have used either (or whatever was nearest) to try to keep the heat down. A million passes with a small endmill would be very counter productive.
Yes, which you won’t get unless the cutter is exactly square to the bed.By exit you mean the back cut?
So effectively the last cut is the back cut?
It really is a crying shame that you are not prepared to post photos of what you are up to. Always sounds really interestingA rather sharp mould, in rather strong sand, which will be poured tomorrow.
Circling the thought of extra stab-finning warily , but think that the sand is strong enough to wangle two or three in...
Maybe....
Others on here are aware.It really is a crying shame that you are not prepared to post photos of what you are up to. Always sounds really interesting![]()
Nah, save that for the weekends.Do you get to play dress up in the suits n everything?
This whole place is a distractive waste of timeOthers on here are aware.
Posting photos on here is a distractive waste of time , but I do share photos and videos via WhatsApp .
To varying degrees, but it is a background illumination of sorts.....This whole place is a distractive waste of time![]()
That really is a waste of time,if you post photos or videos to a select fewOthers on here are aware.
And that's not distractive and a waste of time?Others on here are aware.
What I meant is that the time I spend on here over the years I could probably have finished my café racer and the blardy house renovationTo varying degrees, but it is a background illumination of sorts.....
All that stainless and a bit of aluminium flooring . . . The aluminium was never going to stay perfect!Fitted new stainless chequer flooring to this machine platform today. Much easier to do jobs like this when there's nobody there/not in production.
Top was aluminium but had started corroding and was generally rubbish.
View attachment 472828 View attachment 472829
Especially with the aggressive chemicals they use to keep the stainless clean and hygienic.All that stainless and a bit of aluminium flooring . . . The aluminium was never going to stay perfect!
