Are you working for Nortn Korea or Elon Musk ?Been rolling a load of cones this week, various sizes and taper angles.
This is one of the more awkward ones.
Design decided to have the door laser cut in despite my advice not to.
You can see the distortion around it.
Assuming the shaft lined up when it was first made, has the hull distorted with seagoing, or something?Loads of small jobs this week making brackets and alignment bushings etc for a boat that was having trouble getting a shaft lined up.
It is a heavy built GRP boat so no chance of it moving.Assuming the shaft lined up when it was first made, has the hull distorted with seagoing, or something?
Saw a brembo package recently:Really? Do you have any evidence of that?
I've used Brembo for many years now, never had a problem.
Some good ideas being implemented, cant wait to see the finished article and some of it in use.Second coat of epoxy on the carbon sleeve today, looking good. Unfortunately its going to get painted as the UV resistance of epoxy isnt good & this has to take a lot of stress, it is unstayed & has to carry a 110sq ft Lugsail which has a lot of power. Mast is 5m long 110mm dia at the deck tapering to 60mm at the top.
The carbon sleeve is supplied as a layflat tube & will expand to about 130mm dia & when pulled tight will go down to about 40mm.
Wooden frame is so the black polythene can be dropped over it to hold the heat in from the oil filled radiator. Epoxy likes it warm!
Ocean Gate wanted a new one.Is it a new submarine?
