oldbikedavey
- London, England
Progress on my sand - muller project.....
Needs must, when the devil drives.....
Key and grub screw present.Quite often spec a similar keyway on components, as long as they is held either by another component, or a socket set screw in it onto the key.
I'm currently in the middle of a small project (making a Japanese style box) which was intended as a brief interlude from making a garden table. This was a brief interlude from making the box!
A lot of the old Stanley planes have slotted (yuck) screws. I currently tend to get a screwdriver bit holder handle and then rummage around for a bit that's the right size. I've got some bigger Wiha heavy-duty screwdrivers that would do the job too, but I wanted something fairly short and dedicated to dealing with old-fashioned woodworking tools.
Starting with a couple of bits of silver steel, I ground these to shape on the bench grinder, filed a flat on the shank (to help some epoxy bind them into some yet-to-be-made handles) and then hardened to cherry red and tempered to purpley-blue (as per the recommendations for screwdrivers in the little book I use for reference). I then gave them a good clean up with wet and dry paper:
Above the screwdriver blanks you can see two of the screws that they'll be used with.
Nice !The screwdriver blades (if that's the right word) I made yesterday gained handles today:
I think in this case they are called turnscrews.
They look lovely BTW
Yeah but you live in a valley where the tarmac on the road grows greenMy experience is they will tbh. The horrible leylandi hedge between me and my neighbour has been hacked back like that a few times. It always grows back with a vengeance.
MeI spent all afternoon hand making the latch part ( in the white ) that was missing from this Suffolk latch set that was thrown away by Homebase , for no other reason than it just needed doing, I don't even need the latch
I know you want to know that it filed up a peg on the latch and cold riveted through the plate, forming the countersunk rivet head with a ball pein hammer, how many people these days are using a ball pein for its intended purpose ?
I thought that was just an old-fashioned word for screwdriver.
Thanks.
