Misterg
- North Wales
If it’s the diesel (2.3 litre?) it’ll need bigger than that (probably something with ~800 CCA or more).Have a look at Varta B32 or B34. They are perfect for spinning over 3 litre Essex engines!
Ok good tip thanksCan you remove the cell caps ? If so try cranking the engine over and watch the cells, if you have bubbling in one the cell is shorting out The same principle can be applied when using a high rate discharge tester
Yep diesel 2.5 I believe but you have me doubting myself now.If it’s the diesel (2.3 litre?) it’ll need bigger than that (probably something with ~800 CCA or more).
Could possibly have been made for two 6V batteries originally.Battery box is pretty big
You've probably got 6.5 of your 7.3 ohms resistance due to the black crocodile clip being attached to the vice handle!Me thinks starter is not good.
New battery and same issue.
Took off starter and bench tested. 7.1ohms. seems high to me but I can't find a good number for expected coil resistance. Seems high to me.
12v/7.1ohm ~ 1.6I which seems like a very low start up current for a DC motor.
Make no difference. I always check several places but that was easiest for photo.You've probably got 6.5 of your 7.3 ohms resistance due to the black crocodile clip being attached to the vice handle!
Take it off there and connect it directly to the motor casing.
Thanks, I will take a good look though that. Thanks for taking the time to photo all of that.Here is the section on , starter, from the workshop manual. Start on next post, at bottom pic and it should be in order.
