Kram
- Sussex
I am quite impressed! Cuts bigger sized bits much easier than I imagined, only tested with ivy so far.
Just measured the jaws, 34mm-35mm in the middle, going to 38mm at the end and 59mm tip to tip, so a bit of exaggeration in the listings. I suspect the 40mm advertised ones are equally as good.
One issue is the adjutable jaw size, still very big. Why do you need it? Advertised as a speed feature, but its really more about precisely getting a small branch in the right place without the wide jaws chopping the main stem. Other pruners were advertised with 4 size steps while this just has the two, and I didnt realise the reason at the time.
