Onoff
- Sevenoaks, UK
Ideal for resting your nuts on.
Better than the scrap man getting them (spanners not nuts)Ideal for resting your nuts on.
I've usually used some inch thick styrofoam sheet cut down to below the top edge of the forms to block the leakage out flow and back filled with plenty of topsoil to hold the sheeting strip to the wood .i bet in the uk they would make you dig that rock out and pour a six feet deep found instead
i also wondered if you would drill some rebar into the rock just to tie it in?
One of many nice nac holders.
The frame is made from a gas suppression install kit.
The items from many donations.
I used to use a Jock strapNot a single pipe or cable will be safe in Slovenia from now on....
Do you drill dowels into the rock before placing the concrete?
Impressed! I've no idea how deep the bed rock is here, suspect a LONG way down. Attaching to bedrock sounds brilliant, can't get better.
We'll drill holes in the bedrock about two feet apart and epoxy-in vertical rebars that will extend up out of the footings and into the foundation walls. So it will be well tied into the bedrock. There will be a complete system of properly installed rebar reinforcement within the footings and foundation walls. I'll post pictures as it proceeds.i also wondered if you would drill some rebar into the rock just to tie it in?
If you're interested in the topography/geology, here's a LINK to a bedrock geology map of our area. The garage site is at 43°54'58.13"N, 69°54'44.93"W, and the bedrock type is:River estuary typography. I must see if there's a map somewhere.....
We could use the topsoil to directly brace the outside of the forms, but we'd have to dig it out again to install the perimeter drain system. Temporary pins to secure the bottom edges forms will easy to install. The stone drills quickly with a hammer drill. We'll be installing styrofoam inside the footings and foundation walls.I've usually used some inch thick styrofoam sheet cut down to below the top edge of the forms to block the leakage out flow and back filled with plenty of topsoil to hold the sheeting strip to the wood .
You don't want to be doing it wrong.....I am very tempted, cut crimps off, new cover braid on cable and re crimp. Possibly needs one of those hydraulic crimping tools to do it well.
Would sta-lok or similar type ends be suitable?I am very tempted, cut crimps off, new cover braid on cable and re crimp. Possibly needs one of those hydraulic crimping tools to do it well.
