Kram
- Sussex
Adjusted the chinese 20" bar... New oil hole and enlarged the slot from 8.2 to 9.2mm.
The cheap .325" 76DL chain, I have lengthed and riveted to make 78DL. Now I noticed I'd have an odd number of cutters, does it matter if I have two sequential lefts or rights? I was thinking I should cut it off and have a skip.
Spot the mistake
I thought, ah I could cut the backwards cutter off, then noticed the drive links also a problem.. To save time I started again and got it correct way around and didnt cut off the double cutter.
Rivet punch worked ok but couldnt get it as flat as standard ones.
Lastly I discovered why cheap .325 bars shouldnt be used with a g372xp! The bar is slightly narrower at the mount which means the chain can rub or jam on the casing and the shim plate. Well too much effort spent to abandon. I lightly filed the case edges to a slight chamfer and cut off the offending protrusion of the shim plate. Not ideal but it now moves freely and dont think it will cause any notable problems.
Spot the mistake
I thought, ah I could cut the backwards cutter off, then noticed the drive links also a problem.. To save time I started again and got it correct way around and didnt cut off the double cutter.Rivet punch worked ok but couldnt get it as flat as standard ones.
