The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Pulled from my neighbours skip.
And speaking of Top Cat.
The seller didn't give me a response, he saw the message.
Please update us with a review.I was looking here and there for helicoil sets .
Found interesting things on temu but once in the cart price rised up so I went back to trusty AliExpress searched for Loclifl , discovered an entire world of Loctite knock off .
Now 243 is 30 or 40 euros over here where I live and I'm already using cheaper alternatives.
And ain't going to finish the 50ml bottle too soon (bought 3 or 4 years ago) I've used about half of it considering I've left the thing on a side and lost a bunch of product .
Anyway I wanted to try them out and bought a bunch of them.
Bearings locker, all the fake Loctite I've bought have this on off nozzle under the cap which hopefully will avoid to make a mess if I inadvertently tip them over.View attachment 461113
And the entire selection of thread lockers this specific brand sells
So 222,242,243,263,271,272,290 faketite
Liquid insulation tape just because I think might be useful.
I can't wait to try those out and see if they are worth something.
Anyways I've spent less than buying one single bottle of Loctite
I'll certainly do.Please update us with a review.
Crikey - not seen one of those Tonka tippers since I was very small. Mine had a hard life for several years on many many earth moving sites in various back gardens
I have a greenhouse heater top same as one in pic. Wondered what it was off, any way it's going.A few things.
Plus.........
The contents of the Box.
Green house heater,.
2 Butterfly Pressure Lanterns.
A Vapalux Lantern.
I just junked a base as it was more holes than metalI have a greenhouse heater top same as one in pic. Wondered what it was off, any way it's going.
Vibrating machinery.I'll certainly do.
I can start saying something.
As a machinist I'm pretty confident to say that for most of us Loctite 90% of the times is only really required when something is wrong.
Retaining compound... If a bearing has to be glued in place... Guess what... Something is wrong.
Bad machining, wrong tolerances, something needs to be reclaimed .
Thread lockers as well, if you use the correct size fasteners, torqued to specs, you'll very hardly need Loctite.
We assemble engines after boring, grinding etc
Most of them uses ARP bolts ,or other types of fasteners meant to stretch and bind into the threaded holes.
We never use Loctite, we actually lube the threads to avoid ruptures.
We use thread lockers on hydraulic rods nuts only because we don't replace the self locking nuts, hydraulic pressure can actually go through the threads loosening the nut, an also because the piston might rotate inside the cylinder loosening the nut .
Catastrophic failure often occurs do to the nut becomes loose, sometimes stretching the threads eventually shearing the threaded diameter off the rod, some other times it just falls into the cylinder destroying everything.
The remaining 10% is when you really need thread lockers but you also hardly need to disassemble the bolted components
1% you want to make next guy explode in rage
We all did at least once, when the customer wants to take the work somewhere else because he's cheaper or whatever reason that makes you getting upset.
That's my point of view, of course I'm not talking about high tech engineering.
But there's actually people who use it everywhere without any actual need
