Onoff
- Sevenoaks, UK
You may be able to use a capacitor or a diode / capacitor to give you a pulse from a constant supply.
You draw it I'll make it!
@sparkysy , got any recommendations for wireless safety edges?
I want at least 2, maybe 4, each 1.8 m long.
I use Alexa to deal with all that. I have a simple Alexa relay which pulses the trigger on request. Then Alexa has a routine to do whatever is required according to the instruction... "Alexa, close bomb bay doors", Alexa open gates" etc.
Low-complexity generation of single pulse using RC circuit from a fixed DC supply without the use of a controller
I was looking for a similar solution to this question: I want to generate a pulse (high) of 2 seconds when that DC supply is turned ON. Is there a solution where we can implement this without usin...electronics.stackexchange.com
What, two components?![]()
What sort are you looking for?@sparkysy , got any recommendations for wireless safety edges?
That works for any realistic low voltage. Don't get hung up on values. If it wasn't so late, I would knock it up to show you. It works because a capacitor blocks DC but not AC. The startup of a DC line looks like half a wave of AC, so gets through.5V etc ??? Thought it would just be one cap.
