It should be but the hole is too smallIsn't it standard Schrader ?
oh i have been their before! the day before going away too! 4 new valves needed!I hope they're not Aluminium caps, even if they have the relevant thread, because after a while you won't be able to get them off. Think electrolytic action.
The minor dia. ?See:
What we need to find out is the tapping drill size...
This what I did when I made bullet case valve capsI drilled out some mr men pencil toppers enough to glue a standard valve cap in, would that work ?
But how can they seize, when you take them off for the weekly tyre pressure check……I hope they're not Aluminium caps, even if they have the relevant thread, because after a while you won't be able to get them off. Think electrolytic action.
TPMSBut how can they seize, when you take them off for the weekly tyre pressure check……![]()
I think this would be the best option what glue would you use?I drilled out some mr men pencil toppers enough to glue a standard valve cap in, would that work ?
Ok, I will ask ?TPMS![]()
Ok, I will ask ?
Tyre pressure monitoring system![]()
Think i had some UHU cheap stuff and it worked ok, but it was plastic on plasticI think this would be the best option what glue would you use?
