Onoff
- Sevenoaks, UK
Something not right with this one, it's a funny shape, and not right.
Hexagonal?
Same type of cheap cardboard door, still not got round to replacing it, yeah, very similar situation, stupid animal even cut its paws.
Internet to slow to post a photo.Hexagonal?
Bear with me...Hexagonal?
Our Malinous did similar to our kitchen door so I glued a 4mm sheet hpl on.Same type of cheap cardboard door, still not got round to replacing it, yeah, very similar situation, stupid animal even cut its paws.
But we couldn't put up with its all night whinging, so stuck it in a bathroom the other end of the house.
Hoping to sleep better tonight ?
You trained it well. Getting into a frying pan like object.One of ours has just turned up
Kitten foodIs that food or water ? They love cat/dog food.
I used to do that when I visited the states on business always looked for the surplus stores
You're not trying hard enough - 50ft retracting hosereel from a Super Walmart that was closing down, M12 wheelnuts, air die-grinder, various car parts in one suitcase 20 yrs ago - suitcase did it's job - destroyed protecting the goods - Manchester airport gave me a new one that I still use on shorter trips.These items in USA, my luggage is going to look interesting but aw well
That suggests made in India or Pakistan, which means not made to any tolerance know to man.Probably 3/8 whit
Please feel free to show how to (if you can), make a glass lens, I have no idea.Two more glass lens jobs. Significantly more complex than the last one. But hey, how hard can it be to make them?
View attachment 451249 View attachment 451250
No doubt time will tell, but I’m pretty unfazed….
Only just seeing this post today!@GRW
Those boxes were used to transport mainly Covid but also samples from the regions to Labs for testing during the pandemic. I strongly recommend you clean them inside and out with bleach. You should also remove or cover the UN3373 'Biological substance category B' labelling.
Other than that good find. There were probably 50,000 + of these boxes in use, most were destroyed so these likely went walkies or were left in a van.
Looks like the same one I have. I've only used it a few times & I think it takes a bit of practice to get the hang of it & cut well, but it's easy to hook up and use, & the pilot arc I reckon makes it easier for a newbie.I joined the Parkside Plasma Cutter club last night.
Will have proper look later and see what fittings I need to connect it to my compressor.
I've never used a Megger (& have no idea how to use one). I've relied on my multimeter for basic insulation & resistance tests - but I understand they are the right kit for the job.Here's mine. Well used and abused...View attachment 447870
looks canny enough for the priceI've just acquired a Milwaukee shockwave right-angle-attachment, its impact rated and quite thin so ideal for getting into tight corners. Its 20% off at Toolstation at the moment. I won't buy from Amazon/Ebay as there are loads of cheap copies knocking about. At £20 I thought it was a good buy and makes picking up the usual brackets and postfix from them more interesting.
be even nicer if it had a battery and motor in it
