Nomad
- North Devon (for how long?)
A DIY adjusting tool for the "tamperproof" mixture adjustment on a mid-90s Nissan, glad I finally found a use for a cheap tin spanner that's been in my junk box for decades
It's typical Nissan - more complicated than it needed to be.
The adjusting needle is protected by the loose disk you can see. Using a normal screwdriver turns the disk but not the needle, the needle also has a central pip to make sure you cant just use a thin flat screwdriver.
Next job: keep a look out for a small wooden handle to go on the other end so it looks exactly like the factory tool
