DAPPH
as dyslexik as I'm daft
Can’t wrap people in cotton wool.
Only after the event ???Can’t wrap people in cotton wool.
Only after the event ???Are you using the kiln to slump plate glass?iPhone used to program the temperature controller on the little dental kiln I am using. Added bonus of Wi-Fi is real time data logging so I can see what’s going on without having to go out to the workshop. Controller could do with a bit more PID tuning, but accurate control in a very small kiln was always going to be a challenge.
What's the mould made from. Polished aluminium, perhaps?Into a mold, yes
A coating of what?316 stainless steel with a coating
vegan lard.A coating of what?
Well by dinner time I had working paddle shiftsThis afternoon I tried to make the range rover have paddle shifts
but sadly it wasn't to be, I've something wrong some where either the power to the transmitter
it's a fiddly little un pin job , pin in a piggy back cable and then join the original live . then the receiver feed which is
scotch locked to a switched live under the center console , everything other than those two is pretty much plug and play .
the .I was only on a couple of hours but it started peeing down , I'm hoping the scotch lock just hasn't pierced the small red live feed for the receiver . that'll be a job for tomorrow now ,at least I havn't got to take everything back out again to check it
As we men do I skimmed the destuctions and then skimmed the YT vid as I new better
checked power to the receiver all good but in my undeniable infinite wisdom I'd connected the power for the transmitter to the wrong white plug a rewire to the correct white plug the feed from the slip ring and jobs a gud un . How can one be pleased and annoyed with yourself at the same time
brilliant that , admire that sort of skill/knowledge ,chuffed for you.Well by dinner time I had working paddle shiftsAs we men do I skimmed the destuctions and then skimmed the YT vid as I new better
I can do custom orders to suit your requirementsYou misspelt Strap![]()
Brilliant - well done!
They're actually sunglasses with a camera built into them I put on for recording the gauges but forgot to turn them on... Just like I forgot to use earplugsLove the "safety" goggles!
Well I couldn't resist giving it a little go at home instead of far away from the village, the blower instantly got stuck against the inlet and choked it out and throttle was a bit sensitive hence combo gave large undesirable flames but she wants to run!
Sounds like a prototype Bki cooker . What type of fire extinguishers and stand by help do you have on hand?
