W.olly
- Radcliffe, Manchester
By 22dB aswell. the small one is good but noisy for long use.It will certainly be quieter!
Made in Hainault....Lal are good taps/dies.
Always had this fantasy of traveling the line to the endMade in Hainault....
Always had this fantasy of traveling the line to the end![]()
Too late now. But the steam line runs over most of the old track.
There are still thought to be scorpions living around Ongar station....As it happens, I was speaking with a friend last night. We got onto the subject of the line via a funeral
He said he regrets never having travelled the entire length. I didn't either.
Blue one looks nice.Swapped.a honda eu650 genny for this compressor as wanted an upgrade just to get a belt for it and try it out.
Better than the little red one I hope. View attachment 437511
Yes Pete. The stretch from Epping, or most of it, is a heritage railway. Steam and diesel.Central line? They running Steam to Ongar now?
Red one is 3hp and 13amp plug and runs fine. I used to have a larger twin pump with a 3hp on 13amp plug aswell and ran no problems.Blue one looks nice.
Just out of interest, does the red 3HP compressor blow fuses or can you run it from a 13A plug? I keep seeing used compressors for sale and would like to upgrade to something larger (and quieter!)
I've got identical sets.
I got the same carb set recently, they're cheap but fit everything I've tried them on.View attachment 434613
Carb adjusters, Im sure they are not the best quality. I'll have to check if they fit/work as the tips look a bit less defined than I expected, but it may be that carb screws are like that..
Hex bits, bought for the 10/12mm to make a lathe nut milling holder. Plan to screwcut them M8, M10, M12 and I can make adaptors for any other sizes.
