iNf
- Hereford, England
Did you take a photo of the pothole and tyre with measurements? Put a claim in to local authorityA flippin' puncture, two miles from home, on a wet, debris strewn downhill narrowing winding road, after a bad SMACK into a pothole - pulled over at bottom of hill, extending wheelbrace that came with car, loosened four nuts . . sheared the brace on the fifth . . . Rang the farmer whose driveway I had pulled into, he was okay with it there . . . walked home on the flat winding narrow road . . . found suitable socket, breaker bar, length of pipe, piece of wood, hi-vis and numerous torches . . . walked back . .
Loosened the 5th nut, stood the ~Alfa jack on the piece of wood to stop it sinking in - discovered the standard jack and winding handle are not designed for use under a car - had to use end of handle into winding eye as a lever to turn it half a turn at a time . . . spacer saver on, get home. Can't see anything obvious on wheel or tyre . . . blow it up . . . 1/2" long hole in sidewall of a Vredestein 235/18 winter tyre with years of tread left . . . GRRRRRRRRRRRR
I had to remove a rear wheel and install it on the front, then install the space saver on the rear in order for the car to be drivable again.
clocking what's that !
he' 29 )
