For holding the plastic from falling down it's not so flimsy . . . but when asked to hold up a tonne plus of car at speed when it gets rammed into the ground, maybe not so much?No pics. but fixed other half's VW golf undertray that was hanging down,
Made a small flat bracket that bolted onto subframe and supports the tray.
Why do they make them so that its a flimsy bit of plastic on the edge holding them up!!
I'd be checking things like the accelerator cable (if it has one?) - anything that might have acted as the earth lead and got cooked and is now about to fail itselfPhone call from wife and boy yesterday,
We've broken down in the Fiat 500
What now?
The AA turned up in less than an hour and jump started it so they got home.
On a brief inspection I found this hiding under the battery tray.
Good job it didn't stall on the way back!
A mate had a bit of 25mm multicore cable courtesy of TFL so I made a new lead up.
View attachment 436026View attachment 436025
Cleaned the bolts etc and refitted and now it works ok.
An easy fix after a very poor few weeks of almost everything going wrong.
Seen a few Mini choke cables glowing where people forgot the earth strap years ago.No accelerator cable on this but I know what you mean!
I suspect I may have to do similar on the drivers side of mine - there's a bubble in the paint/sill covering on the drivers side under the rear door.
Today I finished fixing some more rust on my Alfa 159.
This is a bit of a saga, I started in September but I wasn't in a rush, which was just as well.
The rear of the sills are a bit crusty.
This is the worst side, the other side was the same but less so.
Cut out the rust and cleaned it up.
I gave most of the inside two coats of epoxy but I used galv paint on the bits that were to be welded.
Then made a patch.
And welded it in
Cleaned it up and applied two coats of epoxy to the outside with a brush.
That's as far as I got before the test, so I took it for the test.
The test centre with the earliest test available was over 35 miles away and the car hadn't been driven for 6 months but off I headed.
Uneventful trip and the test was started as planned, but they then reversed the car back out of the test centre.
They said there was a fuel leak and they wouldn't carry out the test.
There was no talking to them and I lost the date (and the test fee) so I had to apply for a full new test.
I applied straight away and got a date of February 3rd!
No matter, I don't need the car so I didn't bother looking for a cancellation.
Back home, I checked everything and couldn't find a diesel leak or a leak of anything else.
On further investigation I found it had preformed a DPF regeneration 45 miles ago, so it looks like the smell of diesel was just a hot exhaust.
I was a bit peeved so just let the car sit.
Fast forward to yesterday and I decided to try to try and make the repairs a bit more presentable and closer in colour to the rest of the car.
It's base coat and clear, but now is not the time of year for painting outside so I just gave it a quick lick of 2 pack black.
It was a nice day, very cold and it was almost dark before I started painting.
However, I do have a very powerful infrared heater that warmed the panels nicely and cured the paint in a few minutes (thanks @Pete. )
I'm fairness it turned out ok, and it looks far less obvious than white primer.
I will paint it properly when the weather gets warmer or I get some room cleared to get back inside the garage.
View attachment 436146 View attachment 436143
Yeah it was a fiver in the boot fairNice work!
Do you have a spec or link on the IR heater please?
