zx9
- South East London
I was going to ask.What's its purpose?
Printed with what?Well...not 100% success but the mould itself has worked out pretty well - the filling needs a lot of tweaking though.
It's the rear quarter light rubber for a 1956 Vauxhall...
Printed with what?
I believe that print a few posts back is a mould for that rubber item.
It's polyurethaneYes, but what rubber?
Perfection on the second attempt...Well...not 100% success but the mould itself has worked out pretty well - the filling needs a lot of tweaking though.
View attachment 430615View attachment 430616
Can you not get them from Australia or are they too expensive?Well...not 100% success but the mould itself has worked out pretty well - the filling needs a lot of tweaking though.
2 pack polyurethane rubber2-pack rubber?
Not currently available, someone was supposedly making them over here but not heard anything definite.Can you not get them from Australia or are they too expensive?
I haven't bothered washing it or taking any pictures!The way in which is failed will help you dial in the settings....unfortunately when things go wrong with resin it's usually messy. you need to ensure there's no cured pieces of resin in the vat as they can damage the FEP on the next print.The first resin print has failed in a spectacular fashionI haven't bothered washing it or taking any pictures!
It had broken away from the build plate.
I think it is probably the default settings used, having read a few things online.
I will clean it out and try again tomorrow.
Hopefully I will get something printed soon!
I will run the cleaning cycle tomorrow.The way in which is failed will help you dial in the settings....unfortunately when things go wrong with resin it's usually messy. you need to ensure there's no cured pieces of resin in the vat as they can damage the FEP on the next print.
so.... what's it for?
Legs firmly crossed hereIt's a nut cracker. Used on walnuts so far.
