.I use the rapid for grouting in handrails,wall brackets and railing/balustrade spindles.Can you mix that bostitk into a watery grout?Lots of paint,strangely,one of the jotuns is a red which I didn’t order and it’s not on the delivery note either,so I haven’t paid and I don’t like red anyway,plus 10 calendars,ffs.I use the rapid for grouting in handrails,wall brackets and railing/balustrade spindles.View attachment 430340
That’s just how I use it,says so on the tin.Can you mix that bostitk into a watery grout?
Those flexi drive things are one one my most used tools after a 10 and 13 mm spanner, ideal on jubilee clips, Facom spanners are also my preferred. I have many.A few bits over the last couple of days
a c.k. flexi driver and a gifted pica dry construction pencil ( standard pica for scale ) the big pica takes a oblong lead and the c.k. takes 6mm hex bits
a few facom spanners and a metex silicone block for 6 or 8mm silicone beads far neater than a wet finger .
the spanners were urged by the fact 95% of my spanners are long rather than standard length I'll probably acquire a full set I do like the 440 's
Spotted one of these on FB locally and went for it
Then took this home too
Both 6 months old hardly used
(No pics as both still in car for the might raining sideways!)
