Stueeee
Old git
- N W Kent
I'm trying to add a spur off an existing 32A circuit in my workshop. The picture below gives an idea of my current (failed) attempt to get this wired.
The terminal strip is supposedly a 60A version. There is intended to be another 6MM SWA cable coming out the bottom of the adaptable box which will go to a 5 pin 32A switched socket. The problem is that I can't get the second connection into the hole in the top of the choc block. Any suggestions for a better solution would be most welcome.
